Aller au contenu principal
Samsung Galaxy Light Earpiece Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Back Cover: étape 1, image 1 de 1
    • Before removing the back cover, make sure the Samsung Galaxy Light is completely off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Battery: étape 2, image 1 de 1
    • Remove the battery from the device.
  3. Samsung Galaxy Light Earpiece Speaker Replacement, Unscrew Midframe: étape 3, image 1 de 1
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
  4. Samsung Galaxy Light Earpiece Speaker Replacement, Remove Midframe: étape 4, image 1 de 1
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
  5. Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: étape 5, image 1 de 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: étape 5, image 2 de 3 Samsung Galaxy Light Earpiece Speaker Replacement, Detach Motherboard: étape 5, image 3 de 3
    • To detach the motherboard from the device:
    • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
  6. Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: étape 6, image 1 de 2 Samsung Galaxy Light Earpiece Speaker Replacement, Removing the audio and vibrator: étape 6, image 2 de 2
    • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
4 autres ont terminé cette réparation.
Paul Goyette
Membre depuis le 10/21/14
475 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 700
