Aller au contenu principal
Samsung Galaxy Light USB Charging Port Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Light USB Charging Port Replacement, Remove back cover: étape 1, image 1 de 1
    • Remove the back cover with the opening tool to reveal the battery
  2. Samsung Galaxy Light USB Charging Port Replacement, Remove battery: étape 2, image 1 de 1
    • Now remove the battery and keep it somewhere safe for now
  3. Samsung Galaxy Light USB Charging Port Replacement, Unscrew motherboard from plastic protection: étape 3, image 1 de 1
    • Unscrew the nine screws shown with the Philips #0 screwdriver
    • Be sure not to lose any screws
  4. Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: étape 4, image 1 de 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: étape 4, image 2 de 3 Samsung Galaxy Light USB Charging Port Replacement, Detaching the motherboard: étape 4, image 3 de 3
    • You must detach and replace the entire motherboard the replace the charging port
    • Slowly lift the motherboard up to pull it off the orange strip
    • Pull slowly, you do not want to break this strip
  5. Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: étape 5, image 1 de 2 Samsung Galaxy Light USB Charging Port Replacement, Inserting in new motherboard: étape 5, image 2 de 2
    • Due to the connector being sawdered on you must replace the whole mother boar so, insert your new motherboard
    • Make sure you line it up correctly with the orange strip
3 autres ont terminé cette réparation.
Diandra
Membre depuis le 10/16/14
210 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 membres
5 tutoriels rédigés
3 commentaires
sawdered = soldered...Other than that it is pretty straight forward...thank you...
Jeffrey Harp - Réponse
Typo, Step 4:
“You must detach and replace the entire motherboard the replace the charging port”
the = to
(could have been ‘to’ or ‘then’, but last step dictates it means ‘to replace the port’’
Thanks for the excellent and simple guides!
Kim Lindstrom - Réponse
why dont you just replace the charging port??? any good tech should have that skill in the bank 100%
Philip Moskal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 1,104
