Aller au contenu principal
Samsung Galaxy Luna LCD display Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Luna LCD display Replacement, LCD display: étape 1, image 1 de 1
    • Attach a small suction cup to the lower half of the glass screen.
  2. Samsung Galaxy Luna LCD display Replacement: étape 2, image 1 de 1
    • Apply pressure to the middle section of the screen while pulling up the lower edge by pivoting your wrist.
  3. Samsung Galaxy Luna LCD display Replacement: étape 3, image 1 de 1
    • Once you've opened a large enough gap, insert a Spudger tool between the glass and the motherboard.
    • Slide the Spudger tool around the gap until the screen is completely separated from the motherboard.
    • The LCD is very fragile,be careful when sliding the spudger around the gap.
  4. Samsung Galaxy Luna LCD display Replacement: étape 4, image 1 de 2 Samsung Galaxy Luna LCD display Replacement: étape 4, image 2 de 2
    • Pull the rear panel up and away to completely separate it.
    • make sure the panel is completely detached from the phone frame before separating it.
  5. Samsung Galaxy Luna LCD display Replacement: étape 5, image 1 de 3 Samsung Galaxy Luna LCD display Replacement: étape 5, image 2 de 3 Samsung Galaxy Luna LCD display Replacement: étape 5, image 3 de 3
    • Place the spudger tool between the LCD and the glass screen.
    • Slide the spudger tool in between the screen and the display until both are completely separated from each other.
    • The LCD is very fragile, do not apply excessive force when prying the glass panel
2 autres ont terminé cette réparation.
xingyu chen
Membre depuis le 02/14/18
266 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S6-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S6G1
4 membres
5 tutoriels rédigés
2 commentaires
Hola, cual es el numero de parte de la pantalla a reemplazar?
Luis A. Andueza - Réponse
It appears that OEM screens are no longer available for this phone. I was able to find this third party display assembly that looks like it would work, but I can’t attest to its functionality, so there would be a bit of risk involved for you. Hope that helps!
Austin Blakely -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 1,001
