Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Mega 2 Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Mega 2 Front Facing Camera Replacement, Front Facing Camera: étape 1, image 1 de 1
    • Before beginning, make sure phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 2, image 2 de 2
    • Locate the battery.
    • Use pry tool or fingernail to lift up on the battery.
    • Remove the battery.
    Demander à FixBot
  3. Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 3, image 1 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 3, image 2 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Use phillips head PH000 and remove all 13, 1.4 mm screws as shown.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use tweezers to disconnect the digitizer.
    Demander à FixBot
  4. Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 4, image 1 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 4, image 2 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 4, image 3 de 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembling frame.
    • Remember once the screen is off, completely remove it from the mid-frame.
    • To remove the mid-frame from the motherboard, press down on the top right corner of the frame and the mid-frame should release from the motherboard.
    • When it releases use tweezers to pick up on the mid-frame to completely separate it from the motherboard.
    Demander à FixBot
  5. Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 5, image 1 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 5, image 2 de 3 Samsung Galaxy Mega 2 Front Facing Camera Replacement: étape 5, image 3 de 3
    • Locate the camera in the top left corner.
    • Lift the motherboard connector and remove the camera assembly from phone.
    Demander à FixBot
Taylor Powell
Membre depuis le 09/08/17
804 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 32
Total : 1,105
