Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Mega 2 LCD/Digitizer Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Mega 2 LCD/Digitizer Replacement, LCD/Digitizer: étape 1, image 1 de 1
    • Before beginning, make sure the phone is turned off.
    • On the back of the phone, find the slot at the charging port located at the bottom of the phone.
    • Either insert the plastic opening tool or use your fingernail to pull up on the back cover.
    • Once the corner is released, slide your finger around the outside until the back cover releases.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 2, image 1 de 2 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 2, image 2 de 2
    • Locate the battery
    • Insert fingernail or plastic opening tool into the slot on the bottom of the battery and gently lift up.
    • Remove the battery
    Demander à FixBot
  3. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 3, image 1 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 3, image 2 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 3, image 3 de 3
    • Use phillips head PH000 and remove all 13, 1.4 mm visible screws.
    • Using the pry tool, carefully pop the Digitizer cover off the device.
    • Use the pry tool to disconnect the digitizer
    Demander à FixBot
  4. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 4, image 1 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 4, image 2 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 4, image 3 de 3
    • Insert the pry tool along the side of the device, then work your way around the borders of the screen, separating the screen from the rear assembly frame.
    • Be careful and do not lift the screen completely off yet, leave the screen at an angle.
    • Use the heat gun to heat up the bottom to loosen the adhesive from the menu and back buttons.
    • Once heated, gently pull the screen upward.
    • Make sure that the buttons are separating from the adhesive.
    Demander à FixBot
  5. Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 5, image 1 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 5, image 2 de 3 Samsung Galaxy Mega 2 LCD/Digitizer Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Flip the screen over.
    • Locate the LCD/Digitizer.
    • Then disconnect the LCD/Digitizer using tweezers.
    Demander à FixBot
4 autres ont terminé cette réparation.
Taylor Powell
Membre depuis le 09/08/17
804 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 40
Total : 2,243
