Aller au contenu principal
Samsung Galaxy Mega Front Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Mega Front Facing Camera Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy Mega Front Facing Camera Replacement, Battery: étape 1, image 3 de 3
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
  2. Samsung Galaxy Mega Front Facing Camera Replacement: étape 2, image 1 de 3 Samsung Galaxy Mega Front Facing Camera Replacement: étape 2, image 2 de 3 Samsung Galaxy Mega Front Facing Camera Replacement: étape 2, image 3 de 3
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
  3. Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: étape 3, image 1 de 3 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: étape 3, image 2 de 3 Samsung Galaxy Mega Front Facing Camera Replacement, Midframe: étape 3, image 3 de 3
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
  4. Samsung Galaxy Mega Front Facing Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy Mega Front Facing Camera Replacement: étape 4, image 2 de 2
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
  5. Samsung Galaxy Mega Front Facing Camera Replacement, Front Facing Camera: étape 5, image 1 de 1
    • Remove the one 2.55 mm Phillips #000 screw from top left of motherboard assembly.
  6. Samsung Galaxy Mega Front Facing Camera Replacement: étape 6, image 1 de 1
    • Remove metal cover with plastic opening tool.
  7. Samsung Galaxy Mega Front Facing Camera Replacement: étape 7, image 1 de 2 Samsung Galaxy Mega Front Facing Camera Replacement: étape 7, image 2 de 2
    • Lift the motherboard connector and remove the camera assembly from phone.
3 autres ont terminé cette réparation.
Max Rathman
Membre depuis le 02/04/16
915 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 17-2, Blackwell Winter 2016 Membre de l'équipe USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 673
