Aller au contenu principal
Samsung Galaxy Nexus Main Display Glass Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Nexus Main Display Glass Replacement, Removing Back Cover: étape 1, image 1 de 1
    • Open the back cover of the phone with your fingers or use the plastic opening tools to pry the back cover off of the phone.
    • Remove the battery by prying it free from the divot at the bottom.
    • Store the back cover and the battery in a safe place, such as a bowl, until you are ready to re-install them.
  2. Samsung Galaxy Nexus Main Display Glass Replacement: étape 2, image 1 de 1
    • Remove the four 4.5 mm Phillips screws from the rear of the phone.
  3. Samsung Galaxy Nexus Main Display Glass Replacement: étape 3, image 1 de 2 Samsung Galaxy Nexus Main Display Glass Replacement: étape 3, image 2 de 2
    • Flip the phone over so that the screen faces upward.
    • Insert a plastic opening tool into the seam between the screen and the outer case. Work the plastic opening tool around the phone without removing it from the seam.
    • Slowly pry the outer case from the screen.
    • Work carefully. Excessive force can easily damage the case.
  4. Samsung Galaxy Nexus Main Display Glass Replacement: étape 4, image 1 de 3 Samsung Galaxy Nexus Main Display Glass Replacement: étape 4, image 2 de 3 Samsung Galaxy Nexus Main Display Glass Replacement: étape 4, image 3 de 3
    • Remove a single 4 mm Phillips #00 screw from the bottom of the phone.
    • Lift up the flat connector from its socket on the motherboard.
    • Lift the entire headphone jack assembly from the phone.
  5. Samsung Galaxy Nexus Main Display Glass Replacement: étape 5, image 1 de 2 Samsung Galaxy Nexus Main Display Glass Replacement: étape 5, image 2 de 2
    • Disconnect the two ribbon cables from the motherboard.
  6. Samsung Galaxy Nexus Main Display Glass Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers or a spudger, lift the vibrator motor from its recess in the midframe.
  7. Samsung Galaxy Nexus Main Display Glass Replacement: étape 7, image 1 de 2 Samsung Galaxy Nexus Main Display Glass Replacement: étape 7, image 2 de 2
    • Using tweezers, gently disconnect the antenna cable from its socket on the motherboard.
  8. Samsung Galaxy Nexus Main Display Glass Replacement: étape 8, image 1 de 2 Samsung Galaxy Nexus Main Display Glass Replacement: étape 8, image 2 de 2
    • Use tweezers to pull the motherboard out of the phone.
    • Work carefully. Depending on the model, the underside of the motherboard may still have ribbon cables connecting it to the display assembly.
  9. Samsung Galaxy Nexus Main Display Glass Replacement: étape 9, image 1 de 3 Samsung Galaxy Nexus Main Display Glass Replacement: étape 9, image 2 de 3 Samsung Galaxy Nexus Main Display Glass Replacement: étape 9, image 3 de 3
    • Starting near the USB port, use your tweezers to pull the small daughterboard from the phone.
13 autres ont terminé cette réparation.
Carmine Tenaglia
Membre depuis le 09/15/13
320 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 1-17, Ruszkiewicz Fall 2013 Membre de l'équipe Oakland University, Team 1-17, Ruszkiewicz Fall 2013
OAK-RUSZKIEWICZ-F13S1G17
1 membre
1 tutoriel rédigé
2 commentaires
with this guide , I found this repair easy to do. Thank you Tom G.
Thomas Giles - Réponse
Deberían d3 poner los diagramas eléctricos para reparar gracias
manchadoshow - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 20,703
