Aller au contenu principal
Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: étape 1, image 1 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: étape 1, image 2 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: étape 1, image 3 de 3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 2, image 1 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 2, image 2 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 2, image 3 de 3
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 3, image 1 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 3, image 2 de 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: étape 3, image 3 de 3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
Gavin Tipker
Membre depuis le 11/01/18
193 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G1, Harley Fall 2018 Membre de l'équipe IUPUI, Team S3-G1, Harley Fall 2018
IUPUI-HARLEY-F18S3G1
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 995
