Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Note 3 Display Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove the rear case: étape 1, image 1 de 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: étape 2, image 1 de 2 Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: étape 2, image 2 de 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Demander à FixBot
  3. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: étape 3, image 1 de 2 Samsung Galaxy Note 3 Display Assembly Replacement, Battery: étape 3, image 2 de 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
    Demander à FixBot
  4. Samsung Galaxy Note 3 Display Assembly Replacement, S Pen: étape 4, image 1 de 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
    Demander à FixBot
  5. Samsung Galaxy Note 3 Display Assembly Replacement, Unscrew Back Chassis: étape 5, image 1 de 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
    Demander à FixBot
  6. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Back Chassis: étape 6, image 1 de 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
    Demander à FixBot
  7. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: étape 7, image 1 de 2 Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: étape 7, image 2 de 2
    • Remove the single screw beside headphone jack.
    Demander à FixBot
  8. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: étape 8, image 1 de 2 Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
    Demander à FixBot
  9. Samsung Galaxy Note 3 Display Assembly Replacement, Motherboard Removal: étape 9, image 1 de 1
    • Pull up on the motherboard with tweezers.
    Demander à FixBot
  10. Samsung Galaxy Note 3 Display Assembly Replacement, Spudger Tool Placement: étape 10, image 1 de 1
    • Insert the spudger into the headphone jack.
    Demander à FixBot
  11. Samsung Galaxy Note 3 Display Assembly Replacement, Lift to Separate Headphone Jack: étape 11, image 1 de 1
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
    Demander à FixBot
  12. Samsung Galaxy Note 3 Display Assembly Replacement, Metal Bracket Removal: étape 12, image 1 de 1
    • Remove the metal bracket located in the top left hand corner.
    Demander à FixBot
  13. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Vibrating Motor: étape 13, image 1 de 1
    • Remove the vibrating motor by pulling up on it carefully with the tweezers.
    Demander à FixBot
  14. Samsung Galaxy Note 3 Display Assembly Replacement, USB Port Removal: étape 14, image 1 de 1
    • Lift USB port from the front assembly using the tweezers.
    Demander à FixBot
  15. Samsung Galaxy Note 3 Display Assembly Replacement, Display Assembly: étape 15, image 1 de 1
    • You are now left with the display assembly.
    Demander à FixBot
147 autres ont terminé cette réparation.
Brittany Gail
Membre depuis le 09/23/14
8 581 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 membres
32 tutoriels rédigés
10 commentaires de tutoriel
είναι απόλυτα κατανοητό.
chandr - Réponse Partager
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
rob lang - Réponse Partager
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
tkflenorl - Réponse Partager
sunil - Réponse Partager
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 26
30 derniers jours : 115
Total : 125,036
