This is the notch of your rear cover, this is where you start. Just slide your finger and the back cover comes of very easily
You can either insert your fingernail or simply insert a plastic spudger in the battery's notch
The mid-frame is held by 12 Philips head screws and 1 screw is hidden by a sticker
Be sure you remove the sticker so you can remove the hidden screw that's hidden by a sticker.
Camera and various sensors flex cable
Navigation button flex
Charging port flex
Screen flex
Headphone jack flex
Coaxial antenna (Optional but highly recommended to remove this)
Gently grab the board out, you can also use tweezers to realign the flex cables that getting caught so they won't be causing problems.
You can insert a little bit using your tweezers in the part of the vibration motor. This allows you to create a gap
To reassemble your device, follow these instructions in reverse order. This works on every Note 3s
