Introduction
If you cannot connect the Samsung Galaxy Note 4 to the cellular network, or a Wi-Fi network, you may need to replace the antenna. Follow this guide to replace the antenna in your Samsung Galaxy Note 4.
Ce dont vous avez besoin
Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Grasp the cap of the S Pen and remove it from its slot in the midframe.
Pull up on the connectors with tweezers to detach them from the phone.
19 autres ont terminé cette réparation.
6 commentaires
hi where can i buy an antenna connector ?
i live in india.
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
