Aller au contenu principal
Samsung Galaxy Note Edge Volume Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: étape 1, image 1 de 2 Samsung Galaxy Note Edge Volume Button Replacement, Volume Button: étape 1, image 2 de 2
    • Place your device flat down on a clean surface.
    • Use a Spudger to remove the back cover using the notch at the top left.
  2. Samsung Galaxy Note Edge Volume Button Replacement: étape 2, image 1 de 1
    • Use a Spudger to remove the battery using the notch located underneath the battery.
    • Note: During the creation of this guide, we did not have access to a battery.
  3. Samsung Galaxy Note Edge Volume Button Replacement: étape 3, image 1 de 1
    • Remove the stylus from its sheathe.
  4. Samsung Galaxy Note Edge Volume Button Replacement: étape 4, image 1 de 1
    • Use a Philips #000 Screwdriver to remove the fifteen 4mm screws.
  5. Samsung Galaxy Note Edge Volume Button Replacement: étape 5, image 1 de 1
    • Use a Spudger to remove the black chassis and expose the motherboard.
  6. Samsung Galaxy Note Edge Volume Button Replacement: étape 6, image 1 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 6, image 2 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 6, image 3 de 3
    • Use a Spudger to disconnect the following connections:
    • Connection 1
    • Connection 2
    • Connection 3
  7. Samsung Galaxy Note Edge Volume Button Replacement: étape 7, image 1 de 1
    • Remove the connection for the front camera.
  8. Samsung Galaxy Note Edge Volume Button Replacement: étape 8, image 1 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 8, image 2 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 8, image 3 de 3
    • Do not try to completely remove the motherboard until the final step.
    • Use a Spudger to gently lift the motherboard.
    • Remove the connection of the motherboard and the daughter board.
    • Remove the motherboard.
  9. Samsung Galaxy Note Edge Volume Button Replacement: étape 9, image 1 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 9, image 2 de 3 Samsung Galaxy Note Edge Volume Button Replacement: étape 9, image 3 de 3
    • Remove the volume button panel.
    • Remove the volume button connection.
    • Remove the volume button entirely.
Lizzie Todd
Membre depuis le 04/01/19
301 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G1, Harley Spring 2019 Membre de l'équipe IUPUI, Team S1-G1, Harley Spring 2019
IUPUI-HARLEY-S19S1G1
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 429
