Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Note Front Facing Camera Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Stylus: étape 1, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Stylus: étape 1, image 2 de 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Rear Case: étape 2, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Rear Case: étape 2, image 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    Demander à FixBot
  3. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 3, image 2 de 2
    • Lift and remove the rear case from the phone.
    Demander à FixBot
  4. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Battery: étape 4, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Battery: étape 4, image 2 de 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    Demander à FixBot
  5. Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: étape 5, image 1 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: étape 5, image 2 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement, MicroSD Card: étape 5, image 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    Demander à FixBot
  6. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 6, image 1 de 1
    • Remove the microSD card from its slot in the midframe.
    Demander à FixBot
  7. Samsung Galaxy Note Front Facing Camera Assembly Replacement, SIM Card: étape 7, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, SIM Card: étape 7, image 2 de 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    Demander à FixBot
  8. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 8, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 8, image 2 de 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    Demander à FixBot
  9. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Midframe: étape 9, image 1 de 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    Demander à FixBot
  10. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 10, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 10, image 2 de 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    Demander à FixBot
  11. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 11, image 1 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 11, image 2 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 11, image 3 de 3
    • Slide the plastic opening tool down the seam.
    Demander à FixBot
  12. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 12, image 1 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 12, image 2 de 3 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 12, image 3 de 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    Demander à FixBot
  13. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 13, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 13, image 2 de 2
    • Remove the midframe from the display assembly.
    Demander à FixBot
  14. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Upper Display Assembly Bracket: étape 14, image 1 de 1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
    Demander à FixBot
  15. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 15, image 1 de 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
    Demander à FixBot
  16. Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 16, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement: étape 16, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
    Demander à FixBot
  17. Samsung Galaxy Note Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: étape 17, image 1 de 2 Samsung Galaxy Note Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: étape 17, image 2 de 2
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
    Demander à FixBot
6 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
477 640 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
27 503 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 37
Total : 5,691
