Aller au contenu principal
Samsung Galaxy Note II Speaker Enclosure Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: étape 1, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: étape 1, image 2 de 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: étape 2, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: étape 2, image 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 3, image 1 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 3, image 2 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 3, image 3 de 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: étape 4, image 1 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: étape 4, image 2 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: étape 4, image 3 de 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: étape 5, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: étape 5, image 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 6, image 1 de 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Speaker Enclosure Replacement, Midframe: étape 7, image 1 de 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 8, image 1 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 8, image 2 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 8, image 3 de 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 9, image 1 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 9, image 2 de 3 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 9, image 3 de 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 10, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 10, image 2 de 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 11, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 11, image 2 de 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 12, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 12, image 2 de 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 13, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 13, image 2 de 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 14, image 1 de 2 Samsung Galaxy Note II Speaker Enclosure Replacement: étape 14, image 2 de 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Speaker Enclosure Replacement, Speaker Enclosure: étape 15, image 1 de 1
    • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
  16. Samsung Galaxy Note II Speaker Enclosure Replacement: étape 16, image 1 de 1
    • Remove the speaker enclosure.
9 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
467 548 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 066 tutoriels rédigés
Un commentaire
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 13,849
