Aller au contenu principal
Samsung Galaxy Note Midframe Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note Midframe Replacement, Rear Case: étape 1, image 1 de 2 Samsung Galaxy Note Midframe Replacement, Rear Case: étape 1, image 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  2. Samsung Galaxy Note Midframe Replacement: étape 2, image 1 de 2 Samsung Galaxy Note Midframe Replacement: étape 2, image 2 de 2
    • Lift and remove the rear case from the phone.
  3. Samsung Galaxy Note Midframe Replacement, Battery: étape 3, image 1 de 2 Samsung Galaxy Note Midframe Replacement, Battery: étape 3, image 2 de 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  4. Samsung Galaxy Note Midframe Replacement, MicroSD Card: étape 4, image 1 de 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: étape 4, image 2 de 3 Samsung Galaxy Note Midframe Replacement, MicroSD Card: étape 4, image 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note Midframe Replacement: étape 5, image 1 de 1
    • Remove the microSD card from its slot in the midframe.
  6. Samsung Galaxy Note Midframe Replacement, SIM Card: étape 6, image 1 de 2 Samsung Galaxy Note Midframe Replacement, SIM Card: étape 6, image 2 de 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  7. Samsung Galaxy Note Midframe Replacement: étape 7, image 1 de 2 Samsung Galaxy Note Midframe Replacement: étape 7, image 2 de 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  8. Samsung Galaxy Note Midframe Replacement, Midframe: étape 8, image 1 de 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  9. Samsung Galaxy Note Midframe Replacement: étape 9, image 1 de 2 Samsung Galaxy Note Midframe Replacement: étape 9, image 2 de 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  10. Samsung Galaxy Note Midframe Replacement: étape 10, image 1 de 3 Samsung Galaxy Note Midframe Replacement: étape 10, image 2 de 3 Samsung Galaxy Note Midframe Replacement: étape 10, image 3 de 3
    • Slide the plastic opening tool down the seam.
  11. Samsung Galaxy Note Midframe Replacement: étape 11, image 1 de 3 Samsung Galaxy Note Midframe Replacement: étape 11, image 2 de 3 Samsung Galaxy Note Midframe Replacement: étape 11, image 3 de 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  12. Samsung Galaxy Note Midframe Replacement: étape 12, image 1 de 2 Samsung Galaxy Note Midframe Replacement: étape 12, image 2 de 2
    • Remove the midframe from the display assembly.
16 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
471 486 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 418 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 10,903
