Aller au contenu principal
Samsung Galaxy Note5 Power Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note5 Power Button Replacement, SIM Card Tray: étape 1, image 1 de 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Power Button Replacement: étape 2, image 1 de 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Power Button Replacement, Power Button: étape 3, image 1 de 1
    • Heat the back of the device with a heat gun for 2 minutes
  4. Samsung Galaxy Note5 Power Button Replacement: étape 4, image 1 de 1
    • Once the device is heated, place a suction cup near the bottom of the back of the device Make sure it is placed on the flat part of the glass
    • Be careful holding the device after heating the back, it may burn!
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Power Button Replacement: étape 5, image 1 de 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Power Button Replacement: étape 6, image 1 de 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Power Button Replacement: étape 7, image 1 de 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Power Button Replacement: étape 8, image 1 de 1
    • Remove the S-Pen from the bottom of the device
  9. Samsung Galaxy Note5 Power Button Replacement: étape 9, image 1 de 2 Samsung Galaxy Note5 Power Button Replacement: étape 9, image 2 de 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Power Button Replacement: étape 10, image 1 de 2 Samsung Galaxy Note5 Power Button Replacement: étape 10, image 2 de 2
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Power Button Replacement: étape 11, image 1 de 2 Samsung Galaxy Note5 Power Button Replacement: étape 11, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Loosen the power button flex adhesive by holding it with the tweezers.
    • With the tweezers, pry up and remove the power button flex
  12. Samsung Galaxy Note5 Power Button Replacement: étape 12, image 1 de 1
    • Push out the power button with the tip of the tweezers.
Bernice Nunez
Membre depuis le 04/19/18
340 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G17, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 34
Total : 2,942
