Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Note7 Screen Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note7 Screen Assembly Replacement, Screen Assembly: étape 1, image 1 de 1
    • Apply heat to the back panel, use a guitar pick and suction cup to carefully remove the adhesive and remove the back panel.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Note7 Screen Assembly Replacement: étape 2, image 1 de 1
    • Remove the screws holding the wireless charging and NFC cover in place using a 00 screwdriver, then lift it off.
    Demander à FixBot
  3. Samsung Galaxy Note7 Screen Assembly Replacement: étape 3, image 1 de 1
    • Carefully disconnect and remove the battery by lifting up the connector with either your fingernail or the flat end of a plastic spudger.
    Demander à FixBot
  4. Samsung Galaxy Note7 Screen Assembly Replacement: étape 4, image 1 de 1
    • Remove the five screws holding the speaker pass-through and lift it off.
    Demander à FixBot
  5. Samsung Galaxy Note7 Screen Assembly Replacement: étape 5, image 1 de 2 Samsung Galaxy Note7 Screen Assembly Replacement: étape 5, image 2 de 2
    • Using the flat end of a plastic spudger, carefully remove and lift up every connector on the board.
    • Make sure to press them a little further upward using the spudger, or else they might end up blocking the motherboard from being lifted up, and can also get stuck underneath it during the reassembly process.
    Demander à FixBot
  6. Samsung Galaxy Note7 Screen Assembly Replacement: étape 6, image 1 de 2 Samsung Galaxy Note7 Screen Assembly Replacement: étape 6, image 2 de 2
    • Remove the two screws holding the motherboard to the frame.
    Demander à FixBot
  7. Samsung Galaxy Note7 Screen Assembly Replacement: étape 7, image 1 de 1
    • Using a plastic spudger, lift up the bottom part of the motherboard, then lift it up and out of the frame.
    Demander à FixBot
    • To reassemble the phone with the new screen + midframe, follow these steps in reverse order.
    Demander à FixBot
2 autres ont terminé cette réparation.
Kugel Fisch
Membre depuis le 10/14/25
187 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 34
Total : 251
