Aller au contenu principal
Introduction
By following this guide you should be able to replace the headphone jack in 10-20 minutes. By replacing the headphone jack, you will fix any headphone related audio issues such as static, muffled sounds, or poor earphone audio quality.
Pièces
Aucune pièce spécifiée.
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Headphone Jack Replacement: étape 2, image 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Headphone Jack Replacement: étape 3, image 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Headphone Jack Replacement: étape 4, image 1 de 1
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Headphone Jack Replacement: étape 5, image 1 de 1
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
  6. Samsung Galaxy Prevail Headphone Jack Replacement: étape 6, image 1 de 2 Samsung Galaxy Prevail Headphone Jack Replacement: étape 6, image 2 de 2
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
Ricardo Zuloaga
Membre depuis le 15/09/2016
525 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-6, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 242
