Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Prevail Headphone Jack Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Prevail Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Prevail Headphone Jack Replacement: étape 2, image 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
    Demander à FixBot
  3. Samsung Galaxy Prevail Headphone Jack Replacement: étape 3, image 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
    Demander à FixBot
  4. Samsung Galaxy Prevail Headphone Jack Replacement: étape 4, image 1 de 1
    • Using the nylon spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
    Demander à FixBot
  5. Samsung Galaxy Prevail Headphone Jack Replacement: étape 5, image 1 de 1
    • Using the spudger lift the speaker assembly upward, so you may have access to the headphone assembly.
    • Battery is connected to the motherboard with adhesive backing so use some force when removing the speaker assembly.
    Demander à FixBot
  6. Samsung Galaxy Prevail Headphone Jack Replacement: étape 6, image 1 de 2 Samsung Galaxy Prevail Headphone Jack Replacement: étape 6, image 2 de 2
    • Using the spudger, carefully unplug and remove the headphone port assembly by lifting upward on the ribbon cable.
    • The headphone jack should lift off of the motherboard.
    Demander à FixBot
Ricardo Zuloaga
Membre depuis le 09/15/16
537 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-6, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 21
Total : 656
