Aller au contenu principal
Samsung Galaxy Prevail Rear Camera Lens Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: étape 1, image 1 de 1
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: étape 2, image 1 de 1
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: étape 3, image 1 de 1
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: étape 4, image 1 de 1
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: étape 5, image 1 de 1
    • Replace the secondary rear panel which has the camera lens attached.
Ricardo Zuloaga
Membre depuis le 09/15/16
537 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 17-6, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 297
