Aller au contenu principal
  1. Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Insert an opening tool or fingernail into the tab on the power button side of the phone.
    • Lift on the tab to pry the back cover off of the phone.
    • Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
  2. To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Ignorez les nouveaux gadgets.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    SKIPANDSAVE10
    Save Now
  4. Remove the SD card and Sim card located above the battery bay. (first image) Lift up the plastic plate that covers the LCD ribbon cable. (second image)
    • Remove the SD card and Sim card located above the battery bay. (first image)
    • Lift up the plastic plate that covers the LCD ribbon cable. (second image)
  5. Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back. (their spots are indicated in the image)
    • Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back. (their spots are indicated in the image)
    • Keep the screws on a magnetic mat or in a secure location.
  6. Use a heat gun or a heating device to lightly heat the edges of the screen on the phone Insert an opening tool or credit card between the screen and plastic bezel, then apply pressure to separate.
    • Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
    • Insert an opening tool or credit card between the screen and plastic bezel, then apply pressure to separate.
    • You can also push the screen out in the empty slot where the battery was to push the screen out after heating the screen and plastic bezel.
    • It is important to be quick but careful when separating the screen and plastic bezel because the glue could cool down and re-bond the two parts.
  7. Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit. Lift from the top of the loudspeaker unit to release from the phone. Note that you do not need to remove the motherboard to do this.
    • Use a plastic spudger to disconnect the ribbon cable from the loudspeaker unit.
    • Lift from the top of the loudspeaker unit to release from the phone. Note that you do not need to remove the motherboard to do this.
Alex Boyle
Membre depuis le 31/07/2018
297 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G1, Liner Summer 2018 Membre de l'équipe UW Tacoma, Team S1-G1, Liner Summer 2018
UWT-LINER-SU18S1G1
5 membres
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 171
