Introduction
If your phone is experiencing issues with battery life or will not charge correctly, you may want to consider replacing your battery. Replacing the battery is very simple, as it simply involves removing the rear case and prying out the old battery with fingers. The new battery can then easily be inserted into its place.
Pièces
Aucune pièce nécessaire.
Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
  • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
  • Gently pry apart the rear case from the midframe and remove.
Ajouter un commentaire
Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
  • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
  • Gently pry the battery from the back of the phone.
Daniel Hawkins
Membre depuis le 13/10/2014
323 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 3-3, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 411
