Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy Rush Front Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Rush Front Camera Replacement, Front Camera: étape 1, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement, Front Camera: étape 1, image 2 de 2
    • Looking at the back of your phone, use your finger to remove back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy Rush Front Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 2, image 2 de 2
    • Remove the battery.
    Demander à FixBot
  3. Samsung Galaxy Rush Front Camera Replacement: étape 3, image 1 de 1
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
    Demander à FixBot
  4. Samsung Galaxy Rush Front Camera Replacement: étape 4, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 4, image 2 de 2
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
    Demander à FixBot
  5. Samsung Galaxy Rush Front Camera Replacement: étape 5, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
    Demander à FixBot
  6. Samsung Galaxy Rush Front Camera Replacement: étape 6, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 6, image 2 de 2
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
    Demander à FixBot
  7. Samsung Galaxy Rush Front Camera Replacement: étape 7, image 1 de 1
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
    Demander à FixBot
  8. Samsung Galaxy Rush Front Camera Replacement: étape 8, image 1 de 1
    • Lift the motherboard upwards separating it from your screen.
    Demander à FixBot
  9. Samsung Galaxy Rush Front Camera Replacement: étape 9, image 1 de 1
    • Hold motherboard so that the circuits face away from you
    • Pop off the two black tabs on the upper most part of the motherboard.
    Demander à FixBot
  10. Samsung Galaxy Rush Front Camera Replacement: étape 10, image 1 de 1
    • Flip the motherboard over so that the circuits are now facing your direction.
    Demander à FixBot
  11. Samsung Galaxy Rush Front Camera Replacement: étape 11, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 11, image 2 de 2
    • Lift and remove the connecting tab
    Demander à FixBot
  12. Samsung Galaxy Rush Front Camera Replacement: étape 12, image 1 de 2 Samsung Galaxy Rush Front Camera Replacement: étape 12, image 2 de 2
    • Gently take the front camera with two fingers and pull upwards. A wiggle may help.
    Demander à FixBot
Matthew
Membre depuis le 10/22/14
1 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G4
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 438
