Aller au contenu principal
Samsung Galaxy S Blaze Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: étape 2, image 1 de 1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: étape 3, image 1 de 2 Samsung Galaxy S Blaze Motherboard Replacement: étape 3, image 2 de 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: étape 4, image 1 de 1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: étape 5, image 1 de 3 Samsung Galaxy S Blaze Motherboard Replacement: étape 5, image 2 de 3 Samsung Galaxy S Blaze Motherboard Replacement: étape 5, image 3 de 3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: étape 6, image 1 de 1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 autres ont terminé cette réparation.
Rene Bolanos
Membre depuis le 03/05/15
435 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 11-1, Blackburne Winter 2015 Membre de l'équipe Sam Houston State, Team 11-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 12
Total : 802
