Aller au contenu principal
Samsung Galaxy S Blaze Volume Rocker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: étape 1, image 1 de 1
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 2, image 1 de 1
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 3, image 1 de 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 3, image 2 de 2
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 4, image 1 de 1
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 5, image 1 de 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: étape 5, image 2 de 2
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Jake Best
Membre depuis le 03/05/15
261 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 11-1, Blackburne Winter 2015 Membre de l'équipe Sam Houston State, Team 11-1, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 12
Total : 308
