Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S II T989 Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: étape 1, image 1 de 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: étape 1, image 2 de 3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: étape 1, image 3 de 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: étape 2, image 1 de 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: étape 2, image 2 de 3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
    Demander à FixBot
  3. Samsung Galaxy S II T989 Speaker Replacement: étape 3, image 1 de 3 Samsung Galaxy S II T989 Speaker Replacement: étape 3, image 2 de 3 Samsung Galaxy S II T989 Speaker Replacement: étape 3, image 3 de 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
    Demander à FixBot
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: étape 4, image 1 de 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: étape 4, image 2 de 3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: étape 4, image 3 de 3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
    Demander à FixBot
2 autres ont terminé cette réparation.
Joshua King
Membre depuis le 03/26/14
1 378 Réputation
9 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 membres
27 tutoriels rédigés
3 commentaires de tutoriel
and one would purchase a speaker where?????? :-)
betty - Réponse Partager
speaker jumper ways
Muhammad azan - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 1,951
