Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S II T989 Volume Control Button Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S II T989 Volume Control Button Replacement, Rear Cover: étape 1, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Rear Cover: étape 1, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Rear Cover: étape 1, image 3 de 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S II T989 Volume Control Button Replacement, Battery: étape 2, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Battery: étape 2, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Battery: étape 2, image 3 de 3
    • Turn off the phone before removing battery.
    • The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
    • After the battery starts to lift upwards, use your hand to hold and remove it.
    Demander à FixBot
  3. Samsung Galaxy S II T989 Volume Control Button Replacement, SIM Card: étape 3, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, SIM Card: étape 3, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, SIM Card: étape 3, image 3 de 3
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
    Demander à FixBot
  4. Samsung Galaxy S II T989 Volume Control Button Replacement, Media Card: étape 4, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Media Card: étape 4, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Media Card: étape 4, image 3 de 3
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
    Demander à FixBot
  5. Samsung Galaxy S II T989 Volume Control Button Replacement, Inner Plate: étape 5, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Inner Plate: étape 5, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Inner Plate: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
    Demander à FixBot
  6. Samsung Galaxy S II T989 Volume Control Button Replacement: étape 6, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement: étape 6, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement: étape 6, image 3 de 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
    Demander à FixBot
  7. Samsung Galaxy S II T989 Volume Control Button Replacement, Motherboard: étape 7, image 1 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Motherboard: étape 7, image 2 de 3 Samsung Galaxy S II T989 Volume Control Button Replacement, Motherboard: étape 7, image 3 de 3
    • The motherboard holds many delicate components, improper handling can result in the destruction of these components.
    • To remove the motherboard, first undo the three tabs, indicated by the red outlines, using either a small flat-head screwdriver or your thumbnail.
    • In addition to the three at the top of the motherboard, there is a fourth tab at the bottom of the phone that will need to be opened as well.
    Demander à FixBot
  8. Samsung Galaxy S II T989 Volume Control Button Replacement: étape 8, image 1 de 2 Samsung Galaxy S II T989 Volume Control Button Replacement: étape 8, image 2 de 2
    • After all the tabs are unplugged, carefully apply pressure to the edges of the motherboard and lift upwards.
    • If the motherboard does not lift up, you may need to wiggle it left and right to free the corners from the areas where the case screws were placed.
    Demander à FixBot
  9. Samsung Galaxy S II T989 Volume Control Button Replacement, Volume Control Button: étape 9, image 1 de 2 Samsung Galaxy S II T989 Volume Control Button Replacement, Volume Control Button: étape 9, image 2 de 2
    • Lift the tab indicated by the red rectangle using a pair of tweezers.
    Demander à FixBot
  10. Samsung Galaxy S II T989 Volume Control Button Replacement: étape 10, image 1 de 2 Samsung Galaxy S II T989 Volume Control Button Replacement: étape 10, image 2 de 2
    • After the tab has been lifted press the volume control button inwards until it is free of the frame.
    • A pair of tweezers could be used to help aid in removing the volume control button from the frame.
    Demander à FixBot
2 autres ont terminé cette réparation.
Joshua King
Membre depuis le 03/26/14
1 378 Réputation
9 tutoriels rédigés
Équipe
Clemson, Team 1-5, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 membres
27 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 36
Total : 2,754
