I will teach you how to get down to the midframe. The steps are easy and fast.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Samsung Galaxy S II, utilisez notre manuel de réparation.
Step 1- Use an opening tool, or your fingernail into the opening at the top near the headphone jack.
Use the tool or your fingernail to pry the opening open.
If an microSD card is inserted, use the flat end of a spudger and push it until you hear a click sound and it will release right after.
Once you reassemble the midframe, place the microSD card back into it's slot
Do the exact same thing with your battery and do not damage the battery in any way.
Pry the midframe all around the device to carefully remove it
If you do not pry throughout the whole device, the midframe will be very hard to remove
A plastic tool opener would be better and it will not damage the phone.
Remove the midframe carefully
If your previous midframe was broken, place a new one. When you hear a click sound throughout the device, you know you have snapped it into place
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
