Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S III Battery Replacement
Ce dont vous avez besoin
    1. Samsung Galaxy S III Battery Replacement, Rear Case: étape 1, image 1 de 2 Samsung Galaxy S III Battery Replacement, Rear Case: étape 1, image 2 de 2
      • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
      • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
      • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
      Demander à FixBot
      Ajouter un commentaire
    2. Samsung Galaxy S III Battery Replacement: étape 2, image 1 de 2 Samsung Galaxy S III Battery Replacement: étape 2, image 2 de 2
      • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
      Demander à FixBot
    3. Samsung Galaxy S III Battery Replacement: étape 3, image 1 de 2 Samsung Galaxy S III Battery Replacement: étape 3, image 2 de 2
      • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
      Demander à FixBot
    4. Samsung Galaxy S III Battery Replacement: étape 4, image 1 de 2 Samsung Galaxy S III Battery Replacement: étape 4, image 2 de 2
      • Pry along the top right side, and continue prying down the right side of the rear case.
      Demander à FixBot
    5. Samsung Galaxy S III Battery Replacement: étape 5, image 1 de 2 Samsung Galaxy S III Battery Replacement: étape 5, image 2 de 2
      • Lift up and remove the rear case from the phone.
      • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
      Demander à FixBot
    1. Samsung Galaxy S III Battery Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy S III Battery Replacement, Battery: étape 6, image 2 de 2
      • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
      • Wedge a plastic opening tool into the small notch above the battery.
      • Pry the battery up out of its recess.
      Demander à FixBot
    2. Samsung Galaxy S III Battery Replacement: étape 7, image 1 de 2 Samsung Galaxy S III Battery Replacement: étape 7, image 2 de 2
      • Remove the battery.
      Demander à FixBot
92 autres ont terminé cette réparation.
3 commentaires de tutoriel
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - Réponse Partager
Super simple. Thanks!
bmwherry - Réponse Partager
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 94
Total : 66,961
