Introduction
Use this guide to replace the front panel assembly.
Pièces
- Galaxy S III Screen and Digitizer (T-Mobile)
- Galaxy S III Screen and Digitizer (Verizon)
- Galaxy S III Screen and Digitizer (AT&T/T-Mobile)
- Galaxy S III Screen and Digitizer (US Cellular)
- Samsung Galaxy S III Display Assembly (Digitizer/Front Panel)
- Samsung Galaxy S III Display Assembly I9305 (Digitizer/Front Panel)
- Galaxy S III Screen and Digitizer (Sprint)
- Samsung Galaxy S III S3 Wi-Fi Antenna
- Samsung Galaxy S III S3 Vibrator
- Samsung Galaxy S III S3 Power Button
- Samsung Galaxy S III S3 Volume Button
Vidéo d'introduction
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Remove the single 2.0 mm Phillips screw securing the front-facing camera bracket to the front panel.
Peel the antenna cable up from its channel in the front panel assembly.
Annulation : je n'ai pas terminé ce guide.
203 autre(s) ont terminé cette réparation.
12 commentaires
Thanks. This is the second time I've used this guide.
And how Ill install thenew screen ?
Brilliant Step-By-Step guide. My phone needed new digitizer as just a black screen was showing when turned on, must have happened from a drop. I bought the digitizer screen combo from ebay and used this guide to dress across the components. Worked first time! There are a couple of other spongy or supportive rubber pieces around certain components that were in the original phone so I transferred those also, I guess they are there just to ensure tight connections etc. Absolute lifesaver!
