Aller au contenu principal
Samsung Galaxy S III Front Panel Assembly Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Samsung Galaxy S III Front Panel Assembly Replacement, Rear Case: étape 1, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement, Rear Case: étape 1, image 2 de 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Front Panel Assembly Replacement: étape 2, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 2, image 2 de 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Front Panel Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 3, image 2 de 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Front Panel Assembly Replacement: étape 4, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 4, image 2 de 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Front Panel Assembly Replacement: étape 5, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 5, image 2 de 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Front Panel Assembly Replacement, Battery: étape 6, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement, Battery: étape 6, image 2 de 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Front Panel Assembly Replacement: étape 7, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 7, image 2 de 2
    • Remove the battery.
  8. Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: étape 8, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: étape 8, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement, SIM Card: étape 8, image 3 de 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Front Panel Assembly Replacement: étape 9, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 9, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 9, image 3 de 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: étape 10, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: étape 10, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement, microSD Card: étape 10, image 3 de 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Front Panel Assembly Replacement: étape 11, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 11, image 2 de 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Front Panel Assembly Replacement, Plastic Midframe: étape 12, image 1 de 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Front Panel Assembly Replacement: étape 13, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 13, image 2 de 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Front Panel Assembly Replacement, Headphone Jack/Speaker Assembly: étape 14, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement, Headphone Jack/Speaker Assembly: étape 14, image 2 de 2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Front Panel Assembly Replacement: étape 15, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 15, image 2 de 2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Front Panel Assembly Replacement: étape 16, image 1 de 1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
  17. Samsung Galaxy S III Front Panel Assembly Replacement, Motherboard Assembly: étape 17, image 1 de 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  18. Samsung Galaxy S III Front Panel Assembly Replacement: étape 18, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 18, image 2 de 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  19. Samsung Galaxy S III Front Panel Assembly Replacement: étape 19, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 19, image 2 de 2
    • Disconnect the display data cable from the motherboard.
  20. Samsung Galaxy S III Front Panel Assembly Replacement: étape 20, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 20, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 20, image 3 de 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  21. Samsung Galaxy S III Front Panel Assembly Replacement: étape 21, image 1 de 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  22. Samsung Galaxy S III Front Panel Assembly Replacement: étape 22, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 22, image 2 de 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
  23. Samsung Galaxy S III Front Panel Assembly Replacement, Front-Facing Camera: étape 23, image 1 de 1
    • Remove the single 2.0 mm Phillips screw securing the front-facing camera bracket to the front panel.
  24. Samsung Galaxy S III Front Panel Assembly Replacement: étape 24, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 24, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to lift the front-facing camera/ambient light sensor/rear microphone assembly out from its socket in the front panel assembly.
  25. Samsung Galaxy S III Front Panel Assembly Replacement, Front Panel Assembly: étape 25, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement, Front Panel Assembly: étape 25, image 2 de 2
    • Peel the antenna cable up from its channel in the front panel assembly.
    • Do not completely remove the antenna cable, it is still connected to the antenna board.
  26. Samsung Galaxy S III Front Panel Assembly Replacement: étape 26, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 26, image 2 de 2
    • Wedge the tip of a spudger underneath the earpiece speaker and pry the earpiece speaker out of its recess in the front panel assembly.
  27. Samsung Galaxy S III Front Panel Assembly Replacement: étape 27, image 1 de 1
    • Use the flat edge of a spudger to peel the top portion of the earpiece/volume buttons/ambient light sensor ribbon cable from the front panel assembly.
  28. Samsung Galaxy S III Front Panel Assembly Replacement: étape 28, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 28, image 2 de 2
    • Carefully wedge the flat edge of a spudger underneath the ambient light sensor.
    • Continue peeling the earpiece/volume buttons/ambient light sensor ribbon cable up off the front panel assembly.
  29. Samsung Galaxy S III Front Panel Assembly Replacement: étape 29, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 29, image 2 de 2
    • Insert the flat edge of a spudger underneath the earpiece/volume buttons/ambient light sensor ribbon cable connector.
    • Gently run the spudger across to continue peeling the the earpiece/volume buttons/ambient light sensor ribbon cable from the front panel assembly.
  30. Samsung Galaxy S III Front Panel Assembly Replacement: étape 30, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 30, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 30, image 3 de 3
    • Insert a plastic opening tool in between the the buttons ribbon cable and the volume button.
    • Push the volume out of its recess in the front panel assembly.
    • Lift and remove the volume button out of the phone.
  31. Samsung Galaxy S III Front Panel Assembly Replacement: étape 31, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 31, image 2 de 2
    • Wedge the flat edge of a plastic opening tool in between the the earpiece/buttons/ambient light sensor ribbon cable and run it down to loosen the adhesive securing the ribbon cable.
  32. Samsung Galaxy S III Front Panel Assembly Replacement: étape 32, image 1 de 1
    • Grasp and remove the earpiece/buttons/ambient light sensor ribbon cable out of the phone.
  33. Samsung Galaxy S III Front Panel Assembly Replacement: étape 33, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 33, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 33, image 3 de 3
    • Use a metal spudger to carefully peel the antenna board off the front panel assembly.
    • Lift and remove the antenna board out of the phone.
  34. Samsung Galaxy S III Front Panel Assembly Replacement: étape 34, image 1 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 34, image 2 de 3 Samsung Galaxy S III Front Panel Assembly Replacement: étape 34, image 3 de 3
    • Push the power button out of its recess in the front panel assembly.
    • Remove the power button from the front panel assembly.
  35. Samsung Galaxy S III Front Panel Assembly Replacement: étape 35, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 35, image 2 de 2
    • Use the tip of a spudger to pry the vibrator out of its recess in the front panel assembly.
  36. Samsung Galaxy S III Front Panel Assembly Replacement: étape 36, image 1 de 2 Samsung Galaxy S III Front Panel Assembly Replacement: étape 36, image 2 de 2
    • Use the tip of a spudger to peel the vibrator assembly off the front panel assembly.
  37. Samsung Galaxy S III Front Panel Assembly Replacement: étape 37, image 1 de 1
    • Lift and remove the vibrator out of the front panel assembly.
  38. Samsung Galaxy S III Front Panel Assembly Replacement: étape 38, image 1 de 1
    • Front panel assembly remains.
    • If you are replacing the front panel assembly with a new one, don't forget to transfer all the parts you removed to your new front panel assembly.
212 autres ont terminé cette réparation.
14 commentaires de tutoriel
Hi,
I wonder if this is guide to actually replace broken digitizer - if we have full Digitizer/LCD assembly?
Thanks
Akki S - Réponse
I've just watched the video and... that was pure pleasure to watch repairer. She's professional and beautiful!
paczor - Réponse
Thanks. This is the second time I've used this guide.
William Geisweit - Réponse
And how Ill install thenew screen ?
Lea Efremov - Réponse
Brilliant Step-By-Step guide. My phone needed new digitizer as just a black screen was showing when turned on, must have happened from a drop. I bought the digitizer screen combo from ebay and used this guide to dress across the components. Worked first time! There are a couple of other spongy or supportive rubber pieces around certain components that were in the original phone so I transferred those also, I guess they are there just to ensure tight connections etc. Absolute lifesaver!
James Lainchbury - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 39
7 derniers jours : 247
30 derniers jours : 483
Total : 273,207
