Aller au contenu principal
Samsung Galaxy S III Motherboard Assembly Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Samsung Galaxy S III Motherboard Assembly Replacement, Motherboard Assembly: étape 1, image 1 de 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  2. Samsung Galaxy S III Motherboard Assembly Replacement: étape 2, image 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: étape 2, image 2 de 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  3. Samsung Galaxy S III Motherboard Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: étape 3, image 2 de 2
    • Disconnect the display data cable from the motherboard.
  4. Samsung Galaxy S III Motherboard Assembly Replacement: étape 4, image 1 de 3 Samsung Galaxy S III Motherboard Assembly Replacement: étape 4, image 2 de 3 Samsung Galaxy S III Motherboard Assembly Replacement: étape 4, image 3 de 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  5. Samsung Galaxy S III Motherboard Assembly Replacement: étape 5, image 1 de 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  6. Samsung Galaxy S III Motherboard Assembly Replacement: étape 6, image 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: étape 6, image 2 de 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 8
Total : 144
