Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S Plus Front Panel Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Plus Front Panel Assembly Replacement, Front Panel Assembly: étape 1, image 1 de 2 Samsung Galaxy S Plus Front Panel Assembly Replacement, Front Panel Assembly: étape 1, image 2 de 2
    • Unscrew 7 screws on the rear using a Phillips screw driver.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 2, image 1 de 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 2, image 2 de 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 2, image 3 de 3
    • Unhook the rear using a soft plastic prying tool to remove the rear cover
    • Be careful not to damage the rear cover when unhooking it.
    Demander à FixBot
  3. Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
    Demander à FixBot
  4. Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 4, image 1 de 1
    • Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnecting the camera connector isn't necessary!
    Demander à FixBot
  5. Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 5, image 1 de 1
    • After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • Make sure that the Power Key FPCB does not get stuck!
    Demander à FixBot
  6. Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 6, image 1 de 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 6, image 2 de 3 Samsung Galaxy S Plus Front Panel Assembly Replacement: étape 6, image 3 de 3
    • Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
    • Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
    • Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
    Demander à FixBot
14 autres ont terminé cette réparation.
Joao de Matos
Membre depuis le 07/02/13
383 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 27
Total : 8,967
