Introduction
If your camera stops working or there are constant smudges or discoloration spots in your pictures, your camera lens may be broken or malfunctioning. Replace it by following these steps.
Ce dont vous avez besoin
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Disconnect the ribbon cable and camera lens by tugging gently at the base of the ribbon cable either by pinching with fingers or with the Tweezers.
