Introduction
This guide will take you through all the steps required to access and replace the Headphone Jack and Ear Speaker on your Samsung Galaxy S Vibrant. In order to replace the jack and speaker, you fist will have to remove the battery, the inner back panel, the antenna, and the motherboard.
Ce dont vous avez besoin
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Outil utilisé dans cette étape :Tweezers$4.99
Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
Pull the antenna cable out.
Locate the three snap on ribbon cable connectors on the motherboard.
Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
