Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S Vibrant Loud Speaker Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: étape 1, image 1 de 3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: étape 1, image 2 de 3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: étape 1, image 3 de 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 2, image 1 de 2 Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 2, image 2 de 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
    Demander à FixBot
  3. Samsung Galaxy S Vibrant Loud Speaker Replacement, Midframe: étape 3, image 1 de 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
    Demander à FixBot
  4. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 4, image 1 de 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
    Demander à FixBot
  5. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 5, image 1 de 3 Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 5, image 2 de 3 Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 5, image 3 de 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
    Demander à FixBot
  6. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 6, image 1 de 2 Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 6, image 2 de 2
    • Slide the SD card out of its slot.
    Demander à FixBot
  7. Samsung Galaxy S Vibrant Loud Speaker Replacement, Loud Speaker: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    Phillips #00 Screwdriver
    $5.49
    • Locate the seven screws on the plastic casing.
    • Using the Phillips #00 Screwdriver, remove all seven screws.
    • Be careful not to lose any of these small screws.
    Demander à FixBot
  8. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 8, image 1 de 1
    • Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
    • Be careful not to break any of the plastic snaps.
    Demander à FixBot
  9. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 9, image 1 de 1
    • After all the plastics snaps have been released, the black plastic casing will come off easily.
    • Locate the speaker.
    Demander à FixBot
  10. Samsung Galaxy S Vibrant Loud Speaker Replacement: étape 10, image 1 de 1
    • Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
    • Remove the speaker by gently pulling it.
    Demander à FixBot
Taylor Catlin
Membre depuis le 01/15/13
82 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-37, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 membres
22 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 27
Total : 3,416
