Introduction
Follow this guide to remove the back cover for replacement, or to access the Galaxy S20 Plus’ internals.
You'll need replacement adhesive in order to complete this repair.
Pièces
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
Apply a heated iOpener to the back cover, over the camera bump for two minutes.
Insert an opening pick underneath the corner of the microphone board and wiggle the pick from side to side while sliding it further in.
Tilt the pick to pry up the board and separate the microphone adhesive.
Use a pair of tweezers to remove the microphone from the back cover.
Transfer the microphone to the new back cover.
2 autres ont terminé cette réparation.
