Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to replace the primary and secondary interconnect cables in your Samsung Galaxy S21.
Ce dont vous avez besoin
Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
Use a spudger to pry up and disconnect the secondary interconnect cable's press connector.
Repeat for the main interconnect cable's press connector.
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers or your fingers to remove both cables.
