Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Heat the right edge: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
    Demander à FixBot
  3. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Insert an opening pick: étape 3, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Insert an opening pick: étape 3, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    Demander à FixBot
  4. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the right adhesive: étape 4, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the right adhesive: étape 4, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the right adhesive: étape 4, image 3 de 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
    Demander à FixBot
  5. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Heat the bottom edge: étape 5, image 1 de 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
    Demander à FixBot
  6. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 6, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 6, image 2 de 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
    Demander à FixBot
  7. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the bottom adhesive: étape 7, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the bottom adhesive: étape 7, image 2 de 2
    • Insert a second pick at the bottom right corner.
    • Slide the opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    Demander à FixBot
  8. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Heat the left edge: étape 8, image 1 de 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    Demander à FixBot
  9. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 9, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 9, image 2 de 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    Demander à FixBot
  10. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the left adhesive: étape 10, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the left adhesive: étape 10, image 2 de 2
    • Insert a third opening pick at the bottom left corner.
    • Slide the pick toward the top left corner to separate the adhesive.
    • Leave the pick near the top left corner to prevent the adhesive from resealing.
    Demander à FixBot
  11. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Heat the top edge: étape 11, image 1 de 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
    Demander à FixBot
  12. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 12, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the corner adhesive: étape 12, image 2 de 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
    Demander à FixBot
  13. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the top adhesive: étape 13, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the top adhesive: étape 13, image 2 de 2
    • Insert a fourth opening pick at the top left corner.
    • Slide the pick toward the top right corner to separate the adhesive.
    • Leave the pick near the top right corner to prevent the adhesive from resealing.
    Demander à FixBot
  14. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the rear mic adhesive: étape 14, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Separate the rear mic adhesive: étape 14, image 2 de 2
    • There's a square of adhesive around the rear microphone, just above the flash.
    • Line up the tip of an opening pick with the flash.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
    Demander à FixBot
  15. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the back cover: étape 15, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the back cover: étape 15, image 2 de 2
    • Grab and remove the back cover.
    • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
    • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    Demander à FixBot
  16. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: étape 16, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: étape 16, image 2 de 2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Demander à FixBot
  17. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the wireless charging coil and loudspeaker screws: étape 17, image 3 de 3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
    Demander à FixBot
  18. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the wireless charging coil and loudspeaker: étape 18, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the wireless charging coil and loudspeaker: étape 18, image 2 de 2
    • Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
    • Pry up to unclip the loudspeaker from the frame.
    Demander à FixBot
  19. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 19, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 19, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 19, image 3 de 3
    • Use your fingers to lift the loudspeaker away from the frame.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
    Demander à FixBot
  20. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the battery: étape 20, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the battery: étape 20, image 2 de 2
    • Use a spudger to pry up and disconnect the battery press connector.
    Demander à FixBot
  21. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the interconnect cables: étape 21, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the interconnect cables: étape 21, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the interconnect cables: étape 21, image 3 de 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
    Demander à FixBot
  22. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 22, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 22, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 22, image 3 de 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
    Demander à FixBot
  23. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the interconnect cables: étape 23, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the interconnect cables: étape 23, image 2 de 2
    • Grab and remove the interconnect cables from the phone.
    Demander à FixBot
  24. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: étape 24, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the earpiece speaker: étape 24, image 2 de 2
    • Use a spudger to pry up and disconnect the earpiece speaker press connector.
    Demander à FixBot
  25. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the earpiece speaker screws: étape 25, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the earpiece speaker screws: étape 25, image 2 de 2
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
    Demander à FixBot
  26. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the earpiece speaker: étape 26, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the earpiece speaker: étape 26, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the earpiece speaker: étape 26, image 3 de 3
    • Insert the flat end of a spudger between the bottom edge of the earpiece speaker and the metal plate on the motherboard.
    • Twist the spudger to unclip the earpiece speaker from the frame and remove it.
    • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
    Demander à FixBot
  27. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the upper antenna: étape 27, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the upper antenna: étape 27, image 2 de 2
    • Insert the tip of a spudger under the top left corner of the upper antenna press connector.
    • Do not insert the spudger anywhere else to avoid damaging surface-mounted components.
    • Pry up and disconnect the upper antenna press connector from the motherboard
    Demander à FixBot
  28. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the front camera: étape 28, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the front camera: étape 28, image 2 de 2
    • Insert the tip of a spudger under the bottom right corner of the front camera press connector.
    • Pry up and disconnect the front camera press connector from the motherboard.
    Demander à FixBot
  29. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the display and lower antenna: étape 29, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the display and lower antenna: étape 29, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Disconnect the display and lower antenna: étape 29, image 3 de 3
    • Use a spudger to pry up and disconnect the display and lower antenna cable press connectors from the motherboard.
    Demander à FixBot
  30. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the motherboard screws: étape 30, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the motherboard screws: étape 30, image 2 de 2
    • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the motherboard.
    Demander à FixBot
  31. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the motherboard: étape 31, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the motherboard: étape 31, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the motherboard: étape 31, image 3 de 3
    • Insert the flat end of a spudger between the top edge of the motherboard and the phone frame, in the earpiece speaker cutout.
    • Pry against the frame to lift the motherboard out of its slot and remove it.
    • During reassembly, make sure all of the cables are out of the way before placing the motherboard back into the frame.
    Demander à FixBot
  32. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the SIM card tray: étape 32, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the SIM card tray: étape 32, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the SIM card tray: étape 32, image 3 de 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
    Demander à FixBot
  33. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the daughterboard screws: étape 33, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the daughterboard screws: étape 33, image 2 de 2
    • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the daughterboard.
    Demander à FixBot
  34. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the daughterboard: étape 34, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the daughterboard: étape 34, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the daughterboard: étape 34, image 3 de 3
    • Use the point of a spudger to pry up the top right corner of the daughterboard.
    • Don't pry against the battery. Angle your spudger so you pry against the frame.
    • Remove the daughterboard.
    • During reassembly, reinsert the USB-C port into its recess at an angle before pressing the daughterboard flat onto the frame.
    Demander à FixBot
  35. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Soften the front camera adhesive: étape 35, image 1 de 1
    Demander à FixBot
  36. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the front camera: étape 36, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the front camera: étape 36, image 2 de 2
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the front camera feels stuck. Avoid separating the sensor from the lens, such as this.
    • Use the flat end of a spudger to pry the front camera from its recess in the frame.
    • If the camera doesn't loosen, use a SIM card eject tool to scrape away the epoxy surrounding the camera.
    Demander à FixBot
  37. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 37, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 37, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 37, image 3 de 3
    • Use a spudger to lift the front camera out of its recess until you can grip it with your fingers.
    • Remove the front camera.
    Demander à FixBot
  38. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the upper antenna: étape 38, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the upper antenna: étape 38, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the upper antenna: étape 38, image 3 de 3
    • Insert the point of a spudger into the notch between the bottom edge of the upper antenna and the frame.
    • Pry up and lift the antenna to separate the adhesive securing it.
    • Use your fingers to pull the antenna out of the frame.
    • During reassembly, you may need to transfer the conductive tape under the antenna to your new part.
    Demander à FixBot
  39. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the display cable: étape 39, image 1 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the display cable: étape 39, image 2 de 3 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the display cable: étape 39, image 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the display cable press connector near the bottom edge of the phone.
    • Remove the display cable.
    Demander à FixBot
  40. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the bottom antenna screws: étape 40, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the bottom antenna screws: étape 40, image 2 de 2
    • Use a Phillips screwdriver to remove the two 2.5 mm‑long screws securing the bottom antenna.
    Demander à FixBot
  41. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the lower antenna: étape 41, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Remove the lower antenna: étape 41, image 2 de 2
    • Insert one arm of a pair of angled tweezers or a SIM eject tool into the bottom screw hole on the lower antenna bracket.
    • Pry up and lift the antenna bracket out of its recess enough until you can grip it with your fingers.
    Demander à FixBot
  42. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 42, image 1 de 2 Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement: étape 42, image 2 de 2
    • Lift the bottom antenna out of its recess and remove it.
    Demander à FixBot
  43. Samsung Galaxy S24 Plus Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: étape 43, image 1 de 1
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer additional components or remove adhesive backings during reassembly.
    Demander à FixBot
Spencer Pennington
Membre depuis le 09/09/23
26 184 Réputation
127 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
19 221 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 118
Total : 1,840
