Introduction
If you're finding that you cannot install anything new or save any pictures it is most likely due to the fact that the memory card on the phone is full.
Press and hold the END key to power the phone down.
  • Press and hold the END key to power the phone down.
Ajouter un commentaire
Remove the back cover of the cell phone using a plastic opening tool.
  • Remove the back cover of the cell phone using a plastic opening tool.
The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
Håvard Haugen - Réponse
  • Pry the battery out using a plastic opening tool.
  • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
Does “slide it out” refer to memory card holder or the memory card itself?
Mikko Rantalainen - Réponse
3 autre(s) ont terminé cette réparation.
Arletty
Membre depuis le 25/09/2014
1 022 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 9-2, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 3,829
