Aller au contenu principal
Introduction
Use this guide to replace the display assembly, which includes the front glass, digitizer, and home button cable.
  1. Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone. Gently pry and twist the flexible rear cover off the back of the phone.
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward. Remove the battery away from the phone. Remove the battery away from the phone.
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
  3. Using a fingertip, pull the microSD card straight down out of its slot. Remove the microSD card from the phone.
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
  4. Repeat the above procedure to remove the SIM card.
    • Repeat the above procedure to remove the SIM card.
  5. Use a plastic opening tool to pry up the plastic midframe connector panel. Remove the connector panel with a pair of tweezers. There should be enough adhesive to readhere the panel upon reassembly, otherwise use a small amount of double-stick tape.
    • Use a plastic opening tool to pry up the plastic midframe connector panel.
    • Remove the connector panel with a pair of tweezers.
    • There should be enough adhesive to readhere the panel upon reassembly, otherwise use a small amount of double-stick tape.
  6. Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket. Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
    • Use the sharp tip of a spudger to pry the home button cable connector straight up off its socket.
  7. In the following steps you will be using an iOpener to warm the adhesive affixing the display assembly to the rest of the phone. This will allow for a safer, easier screen removal. For proper iOpener use, follow our iOpener heating guide, make sure to pay attention to all warnings. Place a heated iOpener on the left side of the phone for at least 90 seconds.
    • In the following steps you will be using an iOpener to warm the adhesive affixing the display assembly to the rest of the phone. This will allow for a safer, easier screen removal. For proper iOpener use, follow our iOpener heating guide, make sure to pay attention to all warnings.
    • Place a heated iOpener on the left side of the phone for at least 90 seconds.
    • Reheat the iOpener and place it on the right half of the phone.
  8. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  9. In the following steps you will be using an opening pick to separate the adhesive securing the front panel glass. Only pry where directed. If you experience resistance, stop sliding the opening pick and reapply heat. Insert the edge of an opening pick underneath the bottom right side of the front glass.
    • In the following steps you will be using an opening pick to separate the adhesive securing the front panel glass. Only pry where directed. If you experience resistance, stop sliding the opening pick and reapply heat.
    • Insert the edge of an opening pick underneath the bottom right side of the front glass.
  10. Slide the opening pick up along the right side of the display. Slide the opening pick up along the right side of the display. Slide the opening pick up along the right side of the display.
    • Slide the opening pick up along the right side of the display.
  11. Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone. Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone. Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
    • Carefully slide the pick around the corner, stopping before the speaker grille at the top of the phone.
  12. The adhesive securing the top of the phone is only a narrow strip above the earpiece speaker. Slide the pick along the top of the speaker to avoid damaging internal components. Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply. Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
    • The adhesive securing the top of the phone is only a narrow strip above the earpiece speaker. Slide the pick along the top of the speaker to avoid damaging internal components.
    • Slide the opening pick across the top of the phone, being very careful not to insert the pick too deeply.
  13. Carefully slide the pick around the upper left corner. If you encounter any resistance from cooling adhesive, reapply a heated iOpener to the left side of the phone. If you encounter any resistance from cooling adhesive, reapply a heated iOpener to the left side of the phone.
    • Carefully slide the pick around the upper left corner.
    • If you encounter any resistance from cooling adhesive, reapply a heated iOpener to the left side of the phone.
  14. Slide the opening pick down along the left half of the phone stopping at the lower left corner. Slide the opening pick down along the left half of the phone stopping at the lower left corner. Slide the opening pick down along the left half of the phone stopping at the lower left corner.
    • Slide the opening pick down along the left half of the phone stopping at the lower left corner.
  15. Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed. In the following step you will be placing an iOpener over the home button end of the phone, you won't want your opening pick to slip out.
    • Slide the opening pick all the way to the bottom left corner of the phone, making sure it is securely placed.
    • In the following step you will be placing an iOpener over the home button end of the phone, you won't want your opening pick to slip out.
  16. Place a reheated iOpener over the bottom portion of the display assembly.
    • Place a reheated iOpener over the bottom portion of the display assembly.
    • There are delicate components in this portion of the phone, you want to ensure the adhesive is warm and easy to loosen to protect the phone.
  17. The bottom end of the phone contains the soft button and home button ribbon cables. If you insert the opening pick too far into the phone you risk cutting these cables. Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive. Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
    • The bottom end of the phone contains the soft button and home button ribbon cables. If you insert the opening pick too far into the phone you risk cutting these cables.
    • Slide the very end of the opening pick across the bottom edge of the display to separate the last of the remaining adhesive.
  18. Twist the opening pick to detach the glass from the phone. If the front panel does not detach easily, it may require additional adhesive cutting.
    • Twist the opening pick to detach the glass from the phone.
    • If the front panel does not detach easily, it may require additional adhesive cutting.
  19. If the front panel is not easily freed, the adhesive on the soft button cable may need to be separated. These cables are thin and easily damaged, therefore be certain you are only peeling them off the display assembly and not lacerating them.
    • If the front panel is not easily freed, the adhesive on the soft button cable may need to be separated.
    • These cables are thin and easily damaged, therefore be certain you are only peeling them off the display assembly and not lacerating them.
    • Insert an opening pick under the soft button icons on the display and pry the button cables down off the inside of the front panel.
  20. Slightly lift, but do not remove, the home button end of display assembly. Do not remove the front panel entirely. It is still attached by a connector.
    • Slightly lift, but do not remove, the home button end of display assembly.
    • Do not remove the front panel entirely. It is still attached by a connector.
    • If you are reusing the home button flex cable, be careful not to sever the cable from the home button. Adhesive can cause the cable to rip apart from the home button. While the home button will still work, the fingerprint scanner will not.
  21. Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard. Safely remove the front panel assembly from phone. If your replacement display did not come with a home button, follow our Home Button Assembly guide to transfer your old button over to the new display, or install a new button.
    • Use the sharp tip of a spudger to lift the front panel assembly cable connector straight up off its socket on the motherboard.
    • Safely remove the front panel assembly from phone.
    • If your replacement display did not come with a home button, follow our Home Button Assembly guide to transfer your old button over to the new display, or install a new button.
492 autre(s) ont terminé cette réparation.
Sam Goldheart
Membre depuis le 18/10/2012
388 408 Réputation
545 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
9 430 tutoriels rédigés
60 commentaires
Be aware that the LCD is glued not just at the edges, but also in the middle (the orange areas in the photos for Step 20. These can adhere strongly enough to cause the LCD to crack. Don't ask how I know that.
Nathan Hillery - Réponse
I cracked it this way, so yeah. Any way to get the glue fluetly enough to get the LCD off the rest of the Phone? (the LCD and digitalizer is cracked anyway)
Mick Trompke -
Onfortunately I read this to late. Many thanks anyway for confirming I'm not the only one ;)
tkuilman1 -
Been there man. Had my Samsung Galaxy S5 Active pull one of those numbers. not a fun time.
Cameron Dawson -
Am I missing something?
How does it get re glued when you reverse the process? Doesn't it need to be re glued so water doesn't get into the hardware past the screen?
That would be my concern, the phone not being waterproof after the repairs are completed.
Thanks for your insight. Guide is done very well.
Bogdan.
Bogdan Georgescu - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 51
7 derniers jours : 371
30 derniers jours : 1,673
Total : 716,371
