Introduction
Prerequisite only
Ce dont vous avez besoin
Insert a fingernail or a plastic opening tool into the slot located above the power button.
Gently pull the panel off the back of the phone.
Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
Gently pry the battery away from the phone.
Outil utilisé dans cette étape :iOpener$19.99
Flip the phone and lay it on a flat surface so that the back is facing towards you.
Use a spudger or plastic opening tool to pry up the home button cable connector and disconnect it.
For reassembly, insert the home button cable connector through the open slot in the display assembly.
Use an iOpener to loosen the adhesive beneath the display.
Flip the phone over so it is lying on its back.
Insert a plastic opening tool or a plastic opening pick in the space between the screen and the frame and slide along the right side of the phone to loosen the adhesive.
Gently lift the display assembly away from the frame until there is a small gap and leave the first opening pick in the bottom right corner next to your home button.
Insert a second opening pick and slide it up to the top left corner of the phone by loosening the adhesive beneath the display.
Outil utilisé dans cette étape :Suction Handle$2.99
Use a suction handle to lift the display off of your phone. The home button cable connector should go with the display through a small gap in the mid frame. If it doesn't, use a tweezer to help a little.
Pull the display assembly away from the phone to remove it.
Remove the 12 4 mm Phillips screws #00 from the midframe.
