Aller au contenu principal
Samsung Galaxy S6 Active USB Board Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S6 Active USB Board Replacement, SIM Card: étape 1, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement, SIM Card: étape 1, image 2 de 2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active USB Board Replacement: étape 2, image 1 de 1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: étape 3, image 1 de 3 Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: étape 3, image 2 de 3 Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: étape 3, image 3 de 3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active USB Board Replacement: étape 4, image 1 de 1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active USB Board Replacement: étape 5, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement: étape 5, image 2 de 2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active USB Board Replacement: étape 6, image 1 de 3 Samsung Galaxy S6 Active USB Board Replacement: étape 6, image 2 de 3 Samsung Galaxy S6 Active USB Board Replacement: étape 6, image 3 de 3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active USB Board Replacement: étape 7, image 1 de 1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active USB Board Replacement: étape 8, image 1 de 3 Samsung Galaxy S6 Active USB Board Replacement: étape 8, image 2 de 3 Samsung Galaxy S6 Active USB Board Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active USB Board Replacement: étape 9, image 1 de 1
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active USB Board Replacement: étape 10, image 1 de 1
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active USB Board Replacement, Battery: étape 11, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement, Battery: étape 11, image 2 de 2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active USB Board Replacement: étape 12, image 1 de 1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active USB Board Replacement: étape 13, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement: étape 13, image 2 de 2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active USB Board Replacement: étape 14, image 1 de 1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active USB Board Replacement: étape 15, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement: étape 15, image 2 de 2
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active USB Board Replacement, USB Board: étape 16, image 1 de 2 Samsung Galaxy S6 Active USB Board Replacement, USB Board: étape 16, image 2 de 2
    • Use a plastic opening tool to undo the connector and the two wires on the motherboard.
  17. Samsung Galaxy S6 Active USB Board Replacement: étape 17, image 1 de 1
    • Use the Phillips #000 screwdriver to remove the two 4mm screws from the USB board.
  18. Samsung Galaxy S6 Active USB Board Replacement: étape 18, image 1 de 1
    • Insert a plastic opening tool under the USB board and remove the USB board from the rear case.
Henry Salinas
Membre depuis le 11/07/19
181 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G6, Harley Fall 2019 Membre de l'équipe IUPUI, Team S2-G6, Harley Fall 2019
IUPUI-HARLEY-F19S2G6
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 560
