Introduction
Use this guide either to replace a damaged rear glass panel on your Samsung Galaxy S6 Edge+, or to remove it for access to other components.
Removing the rear glass destroys the adhesive holding it in place. The adhesive will need to be replaced before the rear glass is reinstalled.
Heat an iOpener and apply it to the volume button side of the phone for about two minutes.
First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. The sheet is asymmetrical, so make sure the screw holes in the adhesive sheet line up with the screws on the frame before applying the adhesive.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
3 autre(s) ont terminé cette réparation.
