Introduction
Follow this guide to replace the home button on a Samsung Galaxy S6.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Ce dont vous avez besoin
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on the power button side of the phone.
Press to eject the SIM card tray.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.5mm Phillips #00 screws securing the midframe to the phone.
Firmly grasp the edge of the midframe assembly.
Lift up on the midframe assembly while pushing down on the battery to separate the midframe assembly from the rest of the phone.
While lifting the midframe, be careful to avoid snagging it on the audio jack or charging port.
Once the midframe is partially seperated, carefully run an opening pick around the edges of the rest of the phone to separate the top of the midframe.
To avoid damage to the headphone jack, remove the top of the midframe first, then push the midframe downwards to disengage it from the headphone jack.
You may need to heat and apply an iOpener to the edges of the display to soften the display adhesive if midframe separation is difficult.
Use the flat end of the spudger to disconnect the battery connector from its socket on the motherboard.
Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
If your display glass is badly cracked, tape over the glass to contain stray glass and make prying easier.
Reheat the iOpener.
Lay the iOpener across the S6 display. After two minutes, shift the iOpener to the other half of the screen.
Slide the pick down the edge of the display to separate the adhesive underneath.
Stop cutting when you get to the daughterboard to avoid the delicate capacitive button under the display.
After cutting the adhesive, leave the pick in the side of the display to prevent the display from re-adhering to the frame.
Remove the single 3.0mm Phillips #00 screw securing the daughterboard to the display frame.
Use the pointed edge of the spudger to separate the home button ribbon cable from the display frame.
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
23 autres ont terminé cette réparation.
6 commentaires
So it's literally the last thing you remove on the entire stinking thing /facepalm
You forgot to mention how to enable the fingerprint sensor when you replace the home button. When you replace the home button the fingerprint sensor wont work. Not sure what Samsung does but it has to be a software flash to allow the new part to marry to the mother board. There are lots of how to articles and videos that are half assed and just give enough info to get you into trouble. Though I wouldnt pay Samsung $100 to replace a button, these facts should be included in the repair article. Im really surprised no one has the fix for this in the form of an APK. Ive seen lots of screen replacement videos and all are half assed that show you the wrong way to remove the screen digitizer. I ripped my home button and back buttons circuit because of idiots that post how to videos that skip these important steps. I wish I would have paid the extra $$ and had the local shop do my repair from the start. He told me that the sensor wont work after repair and so far he is correct.
I broke my display doing this :( I suggest you not to do it if you are not 100 % sure of yours skills.
