Introduction
This guide will show you how to replace the Samsung Galaxy S7 Active front camera.
Ce dont vous avez besoin
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers to disconnect the front camera from the battery.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
Use tweezers to remove the connection between the motherboard and the front camera.
Presque terminé !
