Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S7 Active Battery Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: étape 1, image 1 de 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: étape 2, image 1 de 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you do it with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: étape 3, image 1 de 2 Samsung Galaxy S7 Active Battery Replacement: étape 3, image 2 de 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: étape 4, image 1 de 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: étape 5, image 1 de 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: étape 7, image 1 de 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: étape 8, image 1 de 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: étape 9, image 1 de 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: étape 10, image 1 de 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: étape 11, image 1 de 3 Samsung Galaxy S7 Active Battery Replacement: étape 11, image 2 de 3 Samsung Galaxy S7 Active Battery Replacement: étape 11, image 3 de 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: étape 12, image 1 de 2 Samsung Galaxy S7 Active Battery Replacement: étape 12, image 2 de 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
11 autres ont terminé cette réparation.
Alexander Yazdani
Membre depuis le 04/18/18
846 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 membres
15 tutoriels rédigés
4 commentaires de tutoriel
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - Réponse Partager
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - Réponse Partager
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - Réponse Partager
There is a YT video where a famed smartphone repairer makes it look easy but in the comments people are saying they broke their screen. The videographer doesn’t reply to comments.
The guy uses a plastic (I think) business card to lift the screen, sliding it under at the bottom and gradually pulling the protruding sides of the card all the way to the top. I don’t have one so I bought a plastic yogurt carton. I am not sure how well its plastic will withstand heat. A source of heatproof plastic, or nylon card please?
How hot can I heat the screen? I have a non contact thermometer.
I also wonder whether the same glue will work. It doesn’t need to be waterproof.
I think I am going to destroy my phone. I wish there were rugged phone with changeable batteries. I love my S6 active but it is start to not run apps eg LINE.
Timothy Takemoto - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 74
Total : 26,139
