Aller au contenu principal
Samsung Galaxy S7 Active Screen Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: étape 1, image 1 de 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: étape 2, image 1 de 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: étape 3, image 1 de 2 Samsung Galaxy S7 Active Screen Replacement: étape 3, image 2 de 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: étape 4, image 1 de 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: étape 5, image 1 de 3 Samsung Galaxy S7 Active Screen Replacement, Screen: étape 5, image 2 de 3 Samsung Galaxy S7 Active Screen Replacement, Screen: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: étape 6, image 1 de 3 Samsung Galaxy S7 Active Screen Replacement: étape 6, image 2 de 3 Samsung Galaxy S7 Active Screen Replacement: étape 6, image 3 de 3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
3 autres ont terminé cette réparation.
Erick Vazquez
Membre depuis le 04/18/18
180 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 membres
15 tutoriels rédigés
3 commentaires de tutoriel
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Réponse
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Réponse
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 17
Total : 9,432
