Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Samsung Galaxy S8 Active Camera Glass Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S8 Active Camera Glass Replacement, Camera Glass: étape 1, image 1 de 1
    • Lay phone face down and remove any coverings to the camera area. This way there are no obstructions to the repair area.
    Demander à FixBot
    Ajouter un commentaire
  2. Samsung Galaxy S8 Active Camera Glass Replacement: étape 2, image 1 de 1
    • Turn on the heat gun and hold it 3-4 inches from the glass for 5 seconds, waving it gently over the area to evenly distribute heat.
    • It may be helpful to keep the case on during this step, to avoid excessively heating the adhesive of the back panel.
    Demander à FixBot
  3. Samsung Galaxy S8 Active Camera Glass Replacement: étape 3, image 1 de 2 Samsung Galaxy S8 Active Camera Glass Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Gently remove the glass with tweezers.
    • If the adhesive is still strong, utilize the heat gun for another 3-5 seconds, waving it over the area.
    Demander à FixBot
  4. Samsung Galaxy S8 Active Camera Glass Replacement: étape 4, image 1 de 1
    • Check the surface for any residue or broken glass from previous cover.
    Demander à FixBot
  5. Samsung Galaxy S8 Active Camera Glass Replacement: étape 5, image 1 de 1
    • Center the new glass over the camera lens and lower it to the phone, careful to not scratch the exposed camera lens.
    Demander à FixBot
  6. Samsung Galaxy S8 Active Camera Glass Replacement: étape 6, image 1 de 1
    • Press gently on the perimeter of the glass to ensure a strong bond between the glass and the phone, but not pressing hard enough to break the glass.
    Demander à FixBot
The device should be in working condition after the last step. Be sure to turn on the phone and verify to see if there are any obstructions to the camera view caused by the new glass covering.
1 commentaire de tutoriel
Did you use the rear camera glass from Amazon that you've put a link to under parts? The Amazon seller has stated that it doesn't fit the Samsung S8 Active so unsure whether to purchase. Thanks
Natasha Wightman - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 33
Total : 1,219
