Aller au contenu principal
Samsung Galaxy S8 Active Display Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S8 Active Display Replacement, SIM Tray/Card: étape 1, image 1 de 2 Samsung Galaxy S8 Active Display Replacement, SIM Tray/Card: étape 1, image 2 de 2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 1 de 3 Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 2 de 3 Samsung Galaxy S8 Active Display Replacement, NFC Antenna and Charging Coil Assembly: étape 2, image 3 de 3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
  3. Samsung Galaxy S8 Active Display Replacement: étape 3, image 1 de 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active Display Replacement: étape 4, image 1 de 3 Samsung Galaxy S8 Active Display Replacement: étape 4, image 2 de 3 Samsung Galaxy S8 Active Display Replacement: étape 4, image 3 de 3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active Display Replacement: étape 5, image 1 de 1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active Display Replacement: étape 6, image 1 de 2 Samsung Galaxy S8 Active Display Replacement: étape 6, image 2 de 2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active Display Replacement: étape 7, image 1 de 3 Samsung Galaxy S8 Active Display Replacement: étape 7, image 2 de 3 Samsung Galaxy S8 Active Display Replacement: étape 7, image 3 de 3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
  8. Samsung Galaxy S8 Active Display Replacement: étape 8, image 1 de 2 Samsung Galaxy S8 Active Display Replacement: étape 8, image 2 de 2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: étape 9, image 1 de 3 Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: étape 9, image 2 de 3 Samsung Galaxy S8 Active Display Replacement, Loudspeaker Assembly: étape 9, image 3 de 3
    • Remove the loudspeaker assembly using the flat end of a spudger.
  10. Samsung Galaxy S8 Active Display Replacement, Display: étape 10, image 1 de 2 Samsung Galaxy S8 Active Display Replacement, Display: étape 10, image 2 de 2
    • Disconnect the display flex cable on the motherboard using the flat end of a spudger.
  11. Samsung Galaxy S8 Active Display Replacement: étape 11, image 1 de 2 Samsung Galaxy S8 Active Display Replacement: étape 11, image 2 de 2
    • Place the clear side of a heated iOpener over each edge of the phone for about 90 seconds to soften the adhesive attached to the display.
    • Reheat iOpener as needed.
    • A hair dryer or heat gun can also be used to soften the adhesive. A hair dryer/heat gun will make the metal frame hot to the touch, so handle it with care.
  12. Samsung Galaxy S8 Active Display Replacement: étape 12, image 1 de 2 Samsung Galaxy S8 Active Display Replacement: étape 12, image 2 de 2
    • Press a suction handle in the middle of the bottom half of the display.
    • Pull up on the suction cup until there is a small gap in between the display and the frame.
    • If your display is cracked, the suction cup will still pull up the display as one piece.
  13. Samsung Galaxy S8 Active Display Replacement: étape 13, image 1 de 1
    • Insert an opening pick into the gap between the display and the frame created by pulling up on the suction cup.
  14. Samsung Galaxy S8 Active Display Replacement: étape 14, image 1 de 1
    • With the opening pick, continue slicing through the adhesive around the edge of the phone.
    • Once all of the adhesive is separated, remove the display by pulling up on the suction handle.
6 autres ont terminé cette réparation.
Erik Mauk
Membre depuis le 01/24/19
1 426 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S2-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
3 membres
11 tutoriels rédigés
Un commentaire
adding where to and how much of the adhesive to use when putting screen and back panel back on would be a great addition to this guide
jjustin127 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 8,297
